Re: super m oil pressure
Posted by rustred on October 20, 2009 at 12:01:12 from (72.172.100.113):
In Reply to: super m oil pressure posted by jdetig1 on October 20, 2009 at 11:35:44:
it should maintain the oil pres. with the regulator valve in the oil pump. spring may be weak and need replacing.worn brgs also cause pres. loss when the oil heats up.30w oil is good but if pres. drops that much you could go with 40w.are you checking the oil pres. with a master guage?
