Re: super m oil pressure
Posted by Bob M on October 20, 2009 at 12:23:49 from (151.190.254.108):
In Reply to: super m oil pressure posted by jdetig1 on October 20, 2009 at 11:35:44:
30 psi hot is on the low side for a Super M. And as others point out it’s probably from a a combination of worn bearings and a worn/warped oil pump cover.
OTOH unless you need to go inside the engine for something else I wouldn’t be too concerned. I’ve seen Super M run fine for hundreds of hours with only 15 psi showing on the gage at speed, and barely off the pin at idle. Your 30 psi hot should be just fine.
