Posted by M Diesel on October 20, 2009 at 12:47:30 from (12.24.61.12):
In Reply to: W-9 Carb posted by ddownum on October 15, 2009 at 11:12:21:
Hmm. Does the manifold match in size? Does it have an IH part number?
Obviously parts can be swapped but it may require the manifold as well.
Assuming it is original...
It may be a factory arrangement as power units had a lot of engineering tweaks done to them for various reasons. For example, the IH diesel injection pump books are full of variations in settings and governor parts of which almost all are related to power units operating at different speeds and loads.
A larger carb would have been used on a machine that is expected to run fairly well loaded at full RPM all the time. Efficiency under those circumstances would be more important than the ability to provide power at low RPMs or smoothness of idle. A tractor would be optimized for peak efficiency somewhere in the 60% speed/power range and is expected to run nicely across the speed range, while power units typically have only two positions, IDLE and RUN.
It won't necessarily run better at all, but will consume more fuel under light loads due to fuel dispersement problems caused by the drop in velocity.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
