Re: farmall cub
Posted by ScottyHOMEy on October 20, 2009 at 14:59:25 from (71.241.203.43):
In Reply to: farmall cub posted by T.G. Strader on October 20, 2009 at 13:39:33:
The other guys have talked about not enough fuel, and that's a very good possibility, so check out what they suggest in that regard first.
The flip side is too much air. Is the carb tight to the manifold and is the manifold tight to the motor. If there's a leak anyplace there, you'll have too much fuel even if the carb and fuel flow are in good order.
