Re: Engine advice
Posted by El Toro on October 20, 2009 at 16:07:23 from (74.103.74.58):
In Reply to: Engine advice posted by Mark W. on October 20, 2009 at 07:05:31:
Since you don't know anything about the engine other than that it smoked I would pull the engine apart and put in a new sleeve/piston kit.
Have the block cleaned, crankshaft measured for wear and ground undersize if it needs it, have the local auto machine shop furnish the new bearings. Have the head reworked. Then it will be good for a long time. You can check the clutch for wear too. Hal
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
