Re: 806 diesel oil filter conversion kit available?
Posted by Armand Tatro on October 20, 2009 at 17:42:56 from (71.239.10.80):
In Reply to: 806 diesel oil filter conversion kit available? posted by Donald S. Chambers on October 19, 2009 at 09:58:08:
I learned a long time ago that as you tighten the canister you spin it as you tighten the bolt and you will have no leaks assuming you have all the old gasket out of the groove. Makes no matter if you are working on a truck or tractor engine and works on fuel filters also. Works for me! I converted my 560D to spin-on filter and after about a year the adapter gasket started leaking. Took the adapter apart and found old gasket left. Armand
