Re: oil for Farmall C
Posted by Johnjock Gofast on October 20, 2009 at 17:51:18 from (64.231.12.206):
In Reply to: oil for Farmall C posted by Bill Klarer on October 16, 2009 at 09:15:53:
I would not recommend 15w40 for a gas engine. Especially one that is going to be working and hot. I worked on forklift engines for 2 different companies. Same engines used. One company used 15w40, the other used 30. The 40 wt oil caused heavy varnish like deposits on everything inside. When the engine was allowed to cool for a couple of days, the valves and rings would stick and cause compression loss.
The other company that used 30 wt oil never once encountered that problem. Same brand of trucks used under the same conditions.
Just my 2 cents worth.
