Re: 656 doesn't want to split (pics)
Posted by Brownie 450i on March 12, 2009 at 04:56:54 from (216.51.158.151):
In Reply to: 656 doesn't want to split (pics) posted by TX656 on March 11, 2009 at 17:32:43:
Would you please add an angle brace on each side to at least the front stand. Just a flat iron 2 inches wide by 1/2 inch thick would be better than nothing. Angle iron would be better. Go from near the bottom of the vertical supports to a convenient bolt hole on the frame. That front stand will take a lot of stress as you move the engine section forward & back together. It is easier to put a brace in the stand than to pick the front section up off the floor. Back stand could use some angle bracing also. Not trying to be bossy here, but we've split several units & there's a lot of weight involved.
