installing a second set of wheel weights on my 400
Posted by SDE on October 21, 2009 at 14:18:07 from (174.124.26.146):
I have four sets of weights. With the axle clamp bolts at the twelve o'clock positon, I put the longer part of the weight opening, up. This will allow access to the axle bolts with a rachet. By doing this though, I can not slide the square headed bolts behind the first weight because there isn't enough room between it and the spokes of the wheel. If I turn the weight ninty degrees, I will not have enough room for the rachet, only for a flat wrench. Do you put the bolts for the second weight in first and then tighten the first weight in place?
Thank you Steve
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
