Re: McCormick-Deering 22-36
Posted by El Toro on October 21, 2009 at 15:20:03 from (74.103.74.58):
In Reply to: McCormick-Deering 22-36 posted by Tom in Iowa City on October 21, 2009 at 07:35:39:
If you can get the crankshaft out of the block they may be able to press out the sleeves along with pistons at your auto machine shop. Soak them with ATF. If you can get them out your can use an acetylene torch to heat the sleeves. Hal
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
