Re: A oil presure Still 40 to 50
Posted by ScottyHOMEy on October 21, 2009 at 17:31:06 from (71.241.192.2):
In Reply to: A oil presure Still 40 to 50 posted by tackhammertime on October 21, 2009 at 16:46:38:
I'm with tractorman and Red Mist. It sounds like a good tight motor. Unless you have reason to believe that the motor is loose or borderline on being worn out/shot, I wouldn't worry.
Part of it is using straight 30 oil. It will be stiff on a cold start and make more pressure. As a parallel, take the oil pressure gauge on the Cummins in my Ram. It is electronic,not an analog gauge which is pretty annoying -- once the oil is warmed up the gauge stays steady up around 45# whether idling or running hard. But when cold it runs up to about 90# and I can watch it settle back gardually to it's normal reading as the oil warms up.
Does the pressur ecome down once you have the motor warmed up well? If you're really worried about it, try running a bellyfull of 10-30 through it and see if the pressure isn't lower on startup than with the straight 30.
