Kolgie said: (quoted from post at 16:32:30 10/21/09) I am new to this. We have removed the injection pump and had it repaired without lining the engine up first(wrong I now know)To time I know that I have to get the ring gear lined up to 18 degrees and have found that mark. What I need to know is where is the pointer to line up with the 18? I can"t find that anywhere. Is it the cover bolt hole?
On the 86 series tractors the timing marks were moved to the front crank shaft pulley. Line up the correct marks. After bleeding the injectors, if it doesn't start, or if it does start and puts out a lot of smoke and no power, turn the injection pump shaft one turn and try again.
It doesn't seem logical that the engine would run with the injection of fuel coming at the end of the exhaust stroke instead of the compression stroke but I've seen it happen on several different engines.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
