Re: 1086 ring gear timing marks
Posted by Ed pap on October 21, 2009 at 17:51:30 from (74.33.239.233):
In Reply to: 1086 ring gear timing marks posted by Kolgie on October 21, 2009 at 13:32:30:
Owen is correct the timming marks are on the front pully there is a pointer on the front cover. there is a pointer and line on the injection pump gear flange on the pump
the engine needs to be on TDC then 18 deg. if you don't want to remove the valve cover you could take the chance and try it. you have a 50/50 chance it will run correctly. I have seen them start and run 180 deg out it will fill the shop with smoke in seconds.
I would remove the valve cover and get #6 (rear cyl) valves rocken then mount your pump. it wouldn't hurt to do a valve adjustment when your in there. be sure to hold the pump shaft with a socket and line up the marks and tighten the gear bolts, the pump wants to turn off the marks on it's own.
good luck Ed
