Re: Re: Re: H Steering wobble
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Ken on April 22, 2000 at 20:30:09 from (209.250.41.195):
In Reply to: Re: Re: H Steering wobble posted by Ed E on April 22, 2000 at 06:05:58:
Ed I had the same thing I found the nut on top of the steering shaft was loose. It had shered the pin some time. I also replaced the shaft.
Post A Followup
: Re: Re: Re: Re: H Steering wobble
