574 hyd power to loader Question
Posted by Noel Putman on October 22, 2009 at 02:40:45 from (98.223.177.121):
I am trying to install a loader on my 574. The plate on the side of my remote valve has a port in the top that I tapped into for hyd power does not work. Then I found out that IH made 2 versions of that plate. 123104C1 is a "Control Valve Cover" and 123082C1 is a (Control Valve Cover-Power Beyond." Anyway, prior to learning this, I removed the supply line to the loader from the non-functioning 123104C1 plate and installed a fitting on the "Remote Valve Return Line" port by the remote valve to power the loader. I then removed rest of the return line, and capped off the fitting by the hyd filter housing. The return from the loader now goes into the hyd drain fitting.
Question is, will this cause problems or should I get a 123082C1 from Worleys (local ag junkyard) and tap into that?
Thanks
