Posted by SDE on October 22, 2009 at 09:22:24 from (174.124.26.146):
In Reply to: 400 clutch pedal posted by Tom New Jersey on October 22, 2009 at 09:03:16:
Is the shaft the problem? I have removed them and welded the shaft and then turn them back to the original diameter. A person could grind it back to size and finish with a file and sand paper. To much heat will distort the shaft though. After that the pedal has been good enough to use without reworking the pedal. The cast iron pedal is more wear resistant than the steel shaft. SDE
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
