Re: Farmall Super H belt replacement
Posted by jam pa on October 22, 2009 at 09:52:25 from (69.7.97.58):
In Reply to: Farmall Super H belt replacement posted by rednblues08 on October 20, 2009 at 10:38:43:
You will be cursing the Engineer by the time you are finished but it is possible. I understand that this method is 4X less work than pulling the radiator.
My 1st hour was getting the slot head set screw loose so I replaced it with a bolt and anti-seize.
On my H the pulley flat to tap on was inside the schroud so it was a real bugger to get a good hit on. I had my helper trying to hold everything from turning from the other side of the tractor.
I ended up heating the pulley with a propane torch before I could get it loose. Not too hot.
Do not overtighten the belt or the water pump will be junk fast and then you will have some real work to do. I think that the book calls for 3/4" belt flex.
While you are looking at the tractor I would check to make sure that the drain pipe threaded into the bottom of the radiator is tight, I just had mine fall out while brush hogging.
good luck.
