Re: M Serial Number
Posted by rustyfarmall on October 22, 2009 at 14:05:10 from (209.152.78.140):
In Reply to: m serial number (rustyfarmall i got the numbers i think?) posted by farmallhal on October 22, 2009 at 10:15:04:
farmallhal said: (quoted from post at 10:15:04 10/22/09) Rusty, I'm not involved in this string but I have a correct and original 1951 M with a T casting code on the tractor. It is located on the engine block and as I recall was cast in late October 1950. I also have other components with U and W codes. The U was used a short time in early 1951 before going to the W code for 1951 parts. As I recall on my tractor all the U parts had January dates so anything cast in a later month had the W code. The latest casting codes are on the rear cast wheels and were cast in mid-March 1951. My tractor has a 2538XX S/N and from prior research was out of the factory in early April 1951. You should be able to use some of this information to provide Mike a fairly close S/N on his tractor as 41,000 were produced in 1951 when more were made then any other year. Hope this helps, Hal.
Yes, that's why I say the casting codes are good only for a generalization. One book I have insists that the letter "U" was never used, but you just proved that is wrong, and I have observed a few other Farmalls with that "U" casting code.
