Posted by scott mcintosh on October 22, 2009 at 18:17:32 from (216.180.197.191):
In Reply to: 350 hyd posted by robison on October 22, 2009 at 06:43:53:
Flow control valve located on left side of hydraulic valve stack when sitting on tractor.There are four bolts that hold top down remove top but take care when you do,there is heavy spring in there.Orfice located under this cover.Use large flat screwdriver to remove orfice.Helpful hint use a couple of longer bolts to remove and install cover when part way there change those bolts back to the originals.Scott
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
