Re: POP; SuperA pulley
Posted by El Toro on October 23, 2009 at 05:12:21 from (74.103.74.58):
In Reply to: Re: POP; SuperA pulley posted by TWheat on October 22, 2009 at 15:41:31:
third party image
Check with your local Napa store as the seal and sleeve should come as a kit so the sleeve has enough clearance. The installation tool may come with the kit. These speedi-sleeves have been around for a long time and are used in your hydraulic pump if you are getting hydraulic oil into the engine since the seal in there will wear a groove worn from the old seal being brittle from age when item No4 rubs the shaft on item No11. Hal
