Posted by ScottyHOMEy on October 23, 2009 at 06:32:48 from (71.241.192.2):
In Reply to: Re: farmall BN brakes posted by S.Gross(in pa) on October 23, 2009 at 06:02:18:
In that case, you can benefit from trying an adjustment to tighten them. That failing, you could clean or reline/replace them.
Bottom line, though, is that that's one of the weak spots of the design of the brakes on the A, B/BN, and Cub. Beacuse all the tension is applied through the rod to only one end of the band, the geometry and forces at work on them will make them more effective in one direction than another. Given that the tractor is logically capable of greater speed in forward gears than in reverse, they're set up so that forward is the direction with the greater effect.
The C, H and M had a cam mechanism so that tension was aplied from both ends of the band.
Adjustment/relining/replacement (and a little roughing up of the drum as Gene mentioned) will help, but you'll never have the braking in reverse that you do going forward. It's pretty much the nature of the beast. My '47 BN stops quite well going forward and the brakes are adequate for backing just the tractor off of a trailer (10' of dovetail and ramp off a deckover trailer). Where mine show up as weak is in backing off the trailer with an implement (like my #100 spreader) behind.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
