If the bearings are shot, the steel gear rotors will hit the aluminum housing and the pump is history. The only fix is a good replacement pump.
If you think that the pump is the problem, you will have to pressure test it. And flow test it. I would start by disconnecting the pressure line from the priority valve, attaching a high pressure gauge and valve, and a return line from there to the filler hole of the SMTA reservoir. Start the tractor with the valve open and slowly close the valve. Watch the gauge. I think the SMTA pumps are capable of 1200 PSI. Don't totally dead-head the flow if you get that kind of pressure.
If that checks out, the problem will likely be a relief valve in the priority valve. There should be a plug that retains a spring loaded ball. The ball or seat may have a gouge carved into it. Or maybe the spring has collapsed.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
