Posted by Janicholson on October 23, 2009 at 16:59:49 from (64.61.212.54):
In Reply to: Re: M clutch adjust posted by Raymond in co on October 23, 2009 at 15:12:29:
The rod pushes. Find the place where the pedal touches the tractor platform (where your feet are). Push on the pedal with your hand. it should have easy motion for a little, then push much harder. The distance from platform to pedal shank should be 1-1/8 to 1-1/4". Adjust the rod shorter (requires removing the pin, loosening the jamb nut, and turning the clevis on the threads, until the hand pressure freeplay is set. A grabby clutch will not be fixed doing this, but it will be correct. A grabby clutch will either get better with use, or not. If not it can be replaced without splitting the tractor. JimN
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
