Re: hand crank pin?
Posted by Tom Fleming on October 24, 2009 at 03:07:33 from (206.193.247.91):
In Reply to: hand crank pin? posted by Mike CA on October 24, 2009 at 02:30:55:
Mike, it is a standard, hardened steel pin. You can find rod stock at hardware stores, home depot, Lowes, etc. You will need to cut it to length and dress the ends. I am not near my tractors right now, but you can also determine the diameter of the rod. I would think that you want it to extend at least 3/8" to 1/2" out of each side. Also, if you can only buy cold roll, you can temper it by heating to just cherry and quenching in oil. Don't quench in water as it will be too brittle. Also, you want to heat it until it barely starts to glow. If you take it to full cherry, once again it will be too brittle.
IMHO.
