Pressure build up in Battery
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Marvin on April 22, 2000 at 23:43:04 from (209.180.200.188):
I have a 47 Super A that has a 6 volt generator with a cutout regulator. When I run it for 5 to 10 mins or more and the stop it, I hear this hissing of pressure coming from the battery. If I untwist the battery cap I hear the relief of pressure. This tells me that I am probably overcharging the battery.
Has anyone else experienced this? How do I check if the regulator is cutting out when it should.
My amp meter is not working so I cannot tell from that. I can put a voltmeter on it.
Post A Followup
: Re: Pressure build up in Battery
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
