Re: 1948 H gear shift removal and deck
Posted by TomH in PA on October 24, 2009 at 15:33:00 from (67.234.26.50):
In Reply to: 1948 H gear shift removal and deck posted by narrowfarm on October 24, 2009 at 14:58:59:
You could get the cover off without removing the shifter, but it would be hard to get the shifter back in place when you replace the cover.
I can't help you with removing the shifter though, mine's held in place with a pin/hitchpin arrangement. The shifter is under spring tension, press down on it while you tap in the pin to see if that helps.
