The caps are soft metal. Remove the one on the left side of the tractor 1st. I drilled a small hole in the middle and pried it out. You can then use a drift punch and tap the pin against the other cover and it will come off with little or no damage. Make sure the tractor is in neutral as this will make the reinstallation alot easier. I used caulk to seal the hole I drilled in the cover.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
