Yep! You goofed! :P The clip should be on the outside of the oil pan. You can wait to fix it if you want, but you don't have to drop the oil pan to get the clip out, remove the bolt going through the clip and loosen a few bolts on each side, then remove the two bolts holding the breather pipe to the engine cover, slide pipe out of clip and then remove clip. Should not be more than a 5 or 10 min. job.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
