Without the front mounted pump the transmission oil and hydraulic oil should have separate reservoirs.
When the front mounted pump is installed the bottom cover on the hydraulic reservoir is replaced with one that has a standpipe drain. Oil for the front pump is drawn from the transmission through the hydraulic reservoir and then returned to the top of the hydraulic reservoir. Oil for the camshaft gear driven pump is drawn out of the bottom of the hydraulic reservoir only, not from the transmission.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
