Re: Farmall 400, need technical info
Posted by Wardner on October 24, 2009 at 18:39:52 from (4.154.244.90):
In Reply to: Farmall 400, need technical info posted by Nebraska Kirk on October 24, 2009 at 18:04:54:
FWIW, I replaced that bearing in a SMTA many years
ago while doing a TA replacement. I didn't like
the shaft splines or the gear splines of the LPTO
shaft it supports. I opted to replace the bearing,
shaft, and gear.
Mike at Steel Wheel Ranch fixed me up with a good
set. I doubt if I can find the old bearing but I
will take a look. I don't think the
needles/rollers should fall out with normal
handling
Thanks for the IPTO driving gear. I got it
yesterday and started a thread (with picture)
called "My Next Project".
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
