Re: IH 300U fuel system problems
Posted by Rumplestiltskin on October 24, 2009 at 18:47:42 from (96.12.149.74):
In Reply to: IH 300U fuel system problems posted by M Sailer on October 23, 2009 at 12:03:46:
Start it up outside. When it starts to sputter, remove the fuel cap. If it improves, suspect a plugged cap vent causing a vacuum in the tank. Otherwise, check the archives as Dell suggests. There's not really very much to the fuel system -- cap, tank, sediment bulb/screen/valve, fuel line w/carb screen, and carburetor, plus any aftermarket stuff previous owners may have added (e.g., in-line filter). It shouldn't take you too long to zero in on the problem.
Mark W. in MI
