Posted by doug,g on October 24, 2009 at 22:44:26 from (69.66.231.1):
In Reply to: Belt pulley thoughts posted by Mike CA on October 24, 2009 at 22:09:56:
metal will look nicer longer. paper ones when used usually turn black from dirt. but what really matters is getting the right size for your model. the h had a smaller pulley than the m did.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
