Re: Ok, I might be stuck - Genny belt removal
Posted by F-Dean on October 25, 2009 at 06:44:43 from (67.72.98.86):
In Reply to: Ok, I might be stuck - Genny belt removal posted by Mike CA on October 24, 2009 at 21:45:36:
While you have it this far apart, you should replace the short hose between the water pump and the thermostat.
