Owen Aaland said: (quoted from post at 18:11:03 10/24/09) There might be a little space between rollers but not enough for an additional one to be inserted. On the other hand, if the rollers fell out the bearing is worn and should be replaced. A new bearing should be tight enough that the rollers can not come out.
There is enough space for another roller, that is what makes me think I lost one :( When the bearing is on the shaft, it really does not seem worn that much, no more than any of the ball bearings after 53 years of use. I checked with the Case/IH dealer, $110 for the bearing. NAPA can't cross reference the bearing number. I tried measuring the ID and OD of the bearing, but the measurements don't seem to match up with either standard or metric bearings :?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
