Re: H oil dipstick conversion
Posted by D Slater on October 25, 2009 at 08:29:16 from (71.164.44.106):
In Reply to: Re: H oil dipstick conversion posted by rustyfarmall on October 25, 2009 at 07:18:44:
The dipsticks like mike pictured are pretty close if the hole and threads in the oil pan are 90 degrees to the pan mounting rails. If tilted a little it moves the end of dipstick up or down enough to change reading. Easy for the holes to get off square when petcocks are tightend or removed with pipe wrenches and a good bit of pressure. If the oil level was at the bottom of petcock hole it would still have to be a little higher to go through the petcock.
