Re: brush hog mower size for farmall M
Posted by farmallhal on October 25, 2009 at 09:02:13 from (76.4.163.116):
In Reply to: brush hog mower size for farmall M posted by Kurt T on October 25, 2009 at 06:09:19:
My brother-in-law has a M of the same era and he uses a Bush Hog 3008 (8' 2" cutting width) drawbar pull-type which it handles fine. In this area of Missouri the Bush Hog rotary cutters are generally used to maintain our pastures for weed control. It seems to be the perfect size for a M tractor. I have a Bush Hog 3209 which is quite a bit heavier and it seems to be a little much the couple of times he used it. Don't forget you need an over-ride clutch when using one on a M with the transmission driven PTO. Hope this helps, Hal.
