Re: Final drives on Farmall Cub LoBoy-drain where?
Posted by Bigdog on October 25, 2009 at 10:37:53 from (71.64.18.18):
In Reply to: Final drives on Farmall Cub LoBoy-drain where? posted by cdm on October 25, 2009 at 10:11:55:
Yep - drain by removing the pan. You will need replacement gaskets - easily made if you have a sheet of gasket material. Or like mentioned - some use RTV in place of sheet gasket. I prefer a thin coating of RTV on the gasket. Make sure the flanges on the pans are flat. They get pulled down by over-tightening. Replacement gaskets are around $6 from Case IH. (cork)
