Re: Final drives on Farmall Cub LoBoy-drain where?
Posted by farmallhal on October 25, 2009 at 12:14:51 from (76.4.163.116):
In Reply to: Final drives on Farmall Cub LoBoy-drain where? posted by cdm on October 25, 2009 at 10:11:55:
I have a Farmall 140 which has the same arrangement. I was told I could use a suction type pump with a flex line through the filler plug to extract the fluid in that manner from the bottom of the final drive. Maybe one of those drill motor type pumps would work. Never have tried it but might be worth a try if you don't want to go through the removal route. Hope this helps, Hal.
