I just did this job on my 140 last month. Easy enough provided the wheels are not spaced in to the max where they get in your way of removing the bolts. New gaskets are very reasonable from CaseIH.
Everyone seems to have their own way of doing things that work for them, but I am not a user of RTV on gaskets - especially paper or felt. I used a thin coat of gasket sealer (copperhead) on the pan side of the gaskets to hold them in place while I reinstalled the pans. I also put a little on the threads to prevent leaks and to act as a preventive measure for the bolts coming loose. Get the bolts snug, but not extra tight so as to prevent bending the flange on the pans. I started with the center bolts and worked out toward each end.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
