You have it unbolted. Use a porta power between the axles or make a jack bolt from a short piece of pipe, bolt and nut. Place between axles and push the axle from bull gear. Where the axle slides through splines or iner bearing can be tight, or at outer bearing in housing also. Some use the bull gear retaining bolt in axle with spacers between axles to push, but if screwed out to far with a lot of pressure, you risk striping threads.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
