Re: Genny belt saga continues
Posted by rustred on October 25, 2009 at 19:22:30 from (72.172.100.113):
In Reply to: Genny belt saga continues posted by Mike CA on October 25, 2009 at 14:54:50:
mike, you can tighten that gen pulley so that the belt is riding at the top of pully, it can be flush with top. right now it looks like your riding on the btm. you have all kinds of adjustment here. biggest thing is get that pulley loose and lubed up so it turns freely.another thing is there is no slot in that top brace from factory, its just tightened with the pulley.i would just put everything back the way it should be and tighten with the pulley and your good to go.if then that dont take up all the slack spend $20.00 and get the proper belt from IH .
