Nebraska Kirk said: (quoted from post at 19:41:44 10/25/09) The clutch peddle and shaft on my 400 are worn bad too. I ordered a new shaft from A&I. I have yet to bore the hole in clutch peddle hole and install a bushing.
I should clairify: When PK was done you couldn't tell it had been done. Sleeve was pressed in and welded on each end then ground smooth. Hole was drilled through new sleeve for new grease fitting, which they also installed. Beautiful work. Highly recommend.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
