Posted by turboaz on October 26, 2009 at 18:08:13 from (96.245.132.21):
Hello,
I have a 1952 Super A which I have owned almost 2 years now. After I bought it I installed a touch control hydraulic cylinder overhaul kit because it was leaking. Had to pull it off couple of times, because the kit had wrong size o-rings on the control valve piston/cylinders. Anyway finally got that fixed. The hydraulics have been working fine for 2 seasons. I have a rear 60 inch finish mower that I have been lifting and cutting grass. Today I go to move the tractor and the rear lift will not pick up the finish mower. The front lift works okay but only have a snow blade on it - maybe about 100 pounds. I throttled the engine and if I physically assist in lifting the mower somewhat, the rear lift will go up and stay. If I let it down, it will not lift the mower and responds the same way,i.e. if I help lift the mower etc.
Does anyone have an idea why the rear hydraulic system is not working? Do you think it is the hydraulic pump? I checked the fluid level in reservoir and it is up to bottom of hole.
By the way, I changed the fluid 2 or 3 times when I had to pull it off for the o-rings last year so it is clean.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
