Re: Farmall 140 losing coolant
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by ltf in nc on April 23, 2000 at 08:15:20 from (206.228.214.154):
In Reply to: Farmall 140 losing coolant posted by Steve on April 22, 2000 at 11:07:02:
Steve
Since these tractors do not have a coolant recovery tank it is not unusual for the heat expansion of the coolant to force some leaking out the overflow. When cold, if you will leave the level below the neck of the radiator to where you can just touch the coolant with your index finger everything should be O K. As for the leak posted by g, it sounds as if he has a bad seal as the symptoms for a bad seal are as he described.
Post A Followup
: Re: Re: Farmall 140 losing coolant
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
