Posted by charles todd on October 26, 2009 at 19:50:45 from (205.242.95.131):
In Reply to: 706 diesel knock posted by ih54 300 on October 26, 2009 at 15:08:53:
I had one leaking, low psi crack injector (same injectors as your D282) on my Farmall 504 D188. It was causing fuel knock, surging, and black smoke when it "knocked". What is happening is these are indirect injection combustion engines and when an injector is dripping, leaking, or has a low crack psi, it is "flooding" the cylinder with unproperly atomized fuel.
You may have a timing issue. An IH Blue Ribbon Manual or an I&T manual will have the specs.
Here are some pics of my injectors. After 48 years, 3 were still factory spec (1000 psi) and one was (150 psi). I thought it was going to throw a rod on every knock. Mine was RPM sensitive. Wide open it was ok most of the time. Lower RPM'S I'd get the knock.
COMBUSTION CHAMBER
INJECTORS
The #4 (wet one) was the leaker. A gasser with a dead cylinder runs better than a leaking injector on diesel.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
