Re: rust inhibiting coolant?
Posted by John M on October 27, 2009 at 03:08:33 from (67.231.160.184):
In Reply to: Re: rust inhibiting coolant? posted by tractorsam on October 26, 2009 at 18:16:04:
Cavitation is caused by "hot spots" on any metal, and can happen even is gas engines where air is present. Its just more common to see it in diesels because of the slight expansion in the sleeves/cylinders when a diesel fires. The only real way to stop it is to not use water in a diesel cooling system. Evans is the only coolant I know that doesnt use water at all. Evans is real good stuff, but costly, and does exactly what it says it will do. No I dont sell the stuff, just giving some info. I did use it in my Powerstroke with excellent results, but I use Sierra in my tractors simply because I dont know if there would ever be a leak I didnt know about since I dont get to spend everyday with them.
