Re: attaching front wheel weights to Farmall M wide-front
Posted by mkirsch on October 27, 2009 at 05:16:50 from (64.80.108.57):
In Reply to: attaching front wheel weights to Farmall M wide-front posted by Stevie J. Mote on October 26, 2009 at 19:39:51:
Stevie,
You have the original cast hubs on the front of your M, right? If you have an aftermarket front end with aftermarket stamped steel wheels, the OEM weights will not fit.
Three holes on the hub line up with three holes on the weight.
The other three holes are for a second set of weights.
