The oblong hole that's formed by the two weights in a circle allows you to get at the wheel clamp bolts. Line all the weights up.
I would recommend using at least Grade 5 "Reddi Rod." The stuff from your local hardware is usually just Grade 2, and is pretty soft.
The reddi rod method is easiest because you can just stack the weights on, rather than having to hold one or two sets of weights up while trying to thread a bolt.
Normally you would bolt the first set on through the four holes in the center. The second set would use two of the four slots in each half of the first set. The third set would use the two remaining open slots in the second half.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
