Re: SA Clutch adjustment
Posted by rustyfarmall on October 27, 2009 at 12:10:16 from (209.152.78.140):
In Reply to: SA Clutch adjustment posted by Dellbertt on October 27, 2009 at 11:51:32:
If there is too much free travel in the pedal, there could easily be a problem with the clutch not releasing completely, with resulting symptoms such as you describe. Free travel adjustment is just about the only thing that could be at fault unless you have a brand new clutch and pressure plate installed that was never set-up properly to start with.
Hugh would have told you to consult the manual. I will tell you the same thing.
