Re: hyd auger use with an M
Posted by mkirsch on October 27, 2009 at 13:33:53 from (64.80.108.57):
In Reply to: hyd auger use with an M posted by redblood on October 27, 2009 at 08:06:14:
The auger motor valve should have a bypass, basically what Wardner said. It will NOT deadhead the pump.
Just to be safe, try it and see what happens... There's a relief valve in the belly pump to protect it from deadheading. Connect up the auger and pull the belly pump lever. If it starts squealing then it's not bypassing properly.
On an 806, the power beyond is an aftermarket part, not something that comes with the tractor.
